Canon IR1730IF Prints light error reports when faxing only
  • doug
    • Dec 2011
    • 198
    Hi Guys,
    I have a Canon IR1730IF that prints light error reports after faxing....the prints, copies, and incoming and outgoing faxes are fine.
    I tried to change the scan resolution to text only, but did not seem to matter...anyone seen this!?
    Thanking you in advance
    Doug
  • teckat
    • 16083
    Re: Canon IR1730IF Prints light error reports when faxing only
    U receive a printer error report after a successful TX of Fax_?
    =-O
    • doug
      • Dec 2011
      • 198
      =-O
      Thank you for responding teckat...it is not a printer error, it is a tx error that when it prints the report it is always light.
      Everything is fine except it prints the tx error page light.only happens when faxing.(readable, but light)
      Thank you
      Doug
      • teckat
        • 16083
        Thank you
        Doug
        How is issue if you print out a Fax Error report._?
        • doug
          • Dec 2011
          • 198
          Hello teckat... We are bringing the machine back to the shop today, I will send you a sample print...it does it when you print the fax error report too.
          Thank you again
          Doug
          • Jerrygbs
            • Dec 2008
            • 194
            Thank you again
            Doug
            Did you ever find the problem ? I have a 4235 recieving light faxes
            • teckat
              • 16083
              Fax resolution is defined as Standard, Fine, Superfine and Ultrafine.
              (normal - 200x100, fine - 200x200, superfine - 200x400, or ultra fine - 400x400)
              check in settings
