E004-0701 -IRADVC9070
  • rayaeek
    • Apr 2015
    • 15
    [Error Code] E004-0701 -IRADVC9070
    Has anyone had E004-0701, on an iR-ADV C9070, after power cut?
    Upper and lower fuser belts, Fixing base assembly, Relay PCB, DC interface PCB, IH unit & Fuse PCB all replaced.
    Any idea's would be helpful, Thanks.
    Sent from my SM-G901F using Tapatalk
  • dan7777
    • Dec 2012
    • 680
    Re: E004-0701 -IRADVC9070
    I had a E004 on a C7260 that had a busted rear fuser connector. Really hard to replace. If the fixing base assembly was replaced with the front connector, then I would look at rear connector.
    • rayaeek
      • Apr 2015
      • 15
      This rear fixing connector checked and it's okay.
