IR-A-C5035
  • gksapple
    • Apr 2014
    • 116
    [Jamming] IR-A-C5035
    paper jam inside fusing unit
    jam code 0107
    normal printouts and copy working fine in both clr and blk
    issue details:
    *Normal printouts and copy working fine in both BW/clr
    *when printing solid clr in full A4 (100% coverage ) coroner of paper got fold and sticking with the fixing film unit
    *Even printing pg test 10 getting jam on the same place
    Action taken :
    increased the fixing temp but no use
    • 16083
    Re: IR-A-C5035
    jam code 0107
    issue details:
    Action taken :
    LEVEL 2
    Service Mode>COPIER>OPTION>IMG-FIX>PRE-FXRL>set to 1
    This turns on "pressure roller soiling prevention mode".
    paper should stop wrapping around the the fixing unit's pressure roller.
    also check the fixing separation guide position
    ---can be installed upside down by mistake
    ---or >may not be inserted completely
    0107 Jam Fixing--see link
    https://www.dropbox.com/s/y5c1kkbs6j...ixing.pdf?dl=0
    • DarkCrimsonFox
      • Mar 2016
      • 13
      Re: IR-A-C5035
      If what is mention above doesn't work, Maybe try a different stock of paper.
      If the paper has a huge amount of toner, it should runner a tad bit slower through the fixing. At least that is my logic.
      I know from experience that the pressure roller and bearing can cause jams in the fixing.
      Also slim orange roller with the bearing can also cause jams.
      Just clean the bearings.
      Just putting in my two cents.
        • 16083
        Re: IR-A-C5035
        Note:
        Copy\Print speed is determined by paper size, paper type , not amt of toner coverage.
        • Iowatech
          Not a service manager
          • 3930
          Re: IR-A-C5035
          I haven't worked on Canon equipment for years, so this might be a bunch of baloney.
          However, I would guess that an increase in the edge deletion would help prevent jamming of high coverage prints.
          I have been led to believe that is why 12"X18" paper exists.
          Sorry if this is a waste of bandwidth.
            • 16083
            Re: IR-A-C5035
            On a image Runner
            :-)) Borderless print/full bleed
            not possible for copier based model. use 12x18 paper for 11x17 and trim.
            On a Advanced model
            Enlarge Print Area
            Off*, On
            This setting specifies whether to enlarge the printable area on the paper.
            If [Off] is selected, the area 5 mm from the top, bottom, left and right edges of the paper is not printable.
            If [On] is selected, the printable area is enlarged to the top, bottom, left, and right edges of the paper.
            No Borderless Printing*
            • gksapple
              • Apr 2014
              • 116
              Re: IR-A-C5035
              Originally posted by teckat
              LEVEL 2
              Hi
              forgot to fix the fix separation guide,because of that paper jam
              now issue resolved machine ok ,
              thanks for your support
                • 16083
                Re: IR-A-C5035
                Hi
                welcome
