iRC 3220N universal send
  • sgcopiertech
    • Jun 2025
    hi
    i have 2 canon iRc 3220N
    one machine have the universal send function (scan to pc, iFax, scan to email)
    one machine doesn't have.
    i checked the service manual and found that you need 2 items to activate this function:
    1) universal send kit
    2) resolution switching board
    both machine have the resolution switching board.
    can anybody help find out where is the universal send kit located?
    or on how to activate this function.
    thanks in advance!
  • BLITZKREAGG
    U-Send
    on this series of machines (irc 2620 and 3220) the universial send kits are either a parallel or USB port. Color Universal Send Kit- a1p/a1u/a2p/a2u
    any questions let me know.
    Jesses@mbm-idt.com
    • sgcopiertech
      U-send kit
      one guy from another forum replied to my post with this:
      "You will need to get a certificate (purchase the kit). On the certificate is a web address and a product code.
      Go to the website input the product code, serial number and license string on the certificate. The web site will give you a code to enter into the machine. Additional functions/ then either scroll down to license management or it is under the admin settings. All of this is in the license kit."
      is this true?
      • wingnut132
        • 65
        The newer machines what Canon calls LMS, that is the certificate, the older machines use hardware, as stated above you need what they call a dongle, either a parallel or usb, in the us I have only seen parallel.
        • sgcopiertech
          U-send
          would you help me locate where the U-send dongle is located on the 1st machine, i would like to try if i could transfer it to the second machine.
          thanks again for your help!
          • BLITZKREAGG
            U-Send
            What happens is when you plug that dongel into the first machine you have to run through a series of stuff in order to get that u-send on that machine and when you are done it permenently writes the serial number of that machine to that dongel, hence it is not transferable. You would have to purchase another U-Send kit.
            • karta
              • Oct 2009
              • 15
              is this true?
              i already have 24 numbers, and i don't how to entering to the machine?
              • PoonKing5000
                • Jun 2008
                • 111
                I have a few universal send kits a2p new in box. If you are interested email me, bonner09@gmail.com
                Andy
                • mrfixit51
                  Lead Service Technician
                  • Oct 2008
                  • 1975
                  additional functions
                  system settings
                  license registration(2nd or 3rd page I think)
                  • karta
                    • Oct 2009
                    • 15
                    re-activate the invalidation U-send kit ir4570
                    any body can help me, how to re-activate the invalidation numbers for Universal send kit ir4570 after i changed restore the system? or send to coprdn@gmail.com
                    • karta
                      • Oct 2009
                      • 15
                      system settings
                      ok thank's but after i entering the number my 24 number invalid, so I don't have idea
                      • mrfixit51
                        • Oct 2008
                        • 1975
                        Are you "borrowing" this number from another machine?
                        The license application process starts at the Canon LMS website with a certificate number from the package that is input into the webpage along with the serial number of the copier you are going to apply the license to. If you input the wrong serial number into the process, Canon needs to be involved to reissue a different number. If the number was from a different copier, that was used in the key issuing process, the resulting 24# key will not work. It is based on an algorythm, and the mismatch of serial to 24# key will not allow the license to be registered.
                        I have never had difficulty entering a valid license, unless there was missing hardware, at which time the copier will give you the message that those items are needed to accomplish the task.
                        • karta
                          • Oct 2009
                          • 15
                          The license application process starts at the Canon LMS website with a certificate number from the package that is input into the webpage along with the serial number of the copier you are going to apply the license to...... ...........
                          I think my problem now is i don't have a access number for LSM, because i lost it, have idea for me?
                          • mrfixit51
                            • Oct 2008
                            • 1975
                            I am still a little confused here,, what access number are you refering to? If you bought the software,,, in the box is a certificate with the number on it, and the web address of the site that you use to convert your number from the certificate, along with the serial number, into the resulting 24 number string that is the copier license.
                            You will have to contact Canon if this certificate has been lost, but they will need a receipt or some kind of record to assist you. Otherwise you may have to re-purchase the feature and start again.
                            There is no magic pill here, the whole process was well thought out to insure that the end users or service providers were not going to be able to utilyze some feature on the copier without paying Canon there fee for it's useage.
