Hello , im facing a werid problem in ir advc5030i ,it working perfectly when i just want to make init-4 on service mode , the machine gave me error code e00020-0011 ,then i tried init-y it gave the error also i tried init-k it gave me also error but another ext-0014 i changed the yellow drum , still y error code occuar ,i changed the itb belt and same problem checked the patch sensor guide its not broken and i also cleaned it same error 0014 i made clear dc and same error occuar when i make init ,werid honestly first time i face this any one can help me thanks.
IR-A-C5035 e00020-0011 and the -0014
Re: IR-A-C5035 e00020-0011 and the -0014
No i didnt replaced them its counter 13% looks new but cos the machine came from abroad and i want to make a full repair before i sold it cos of that i said to make init-4 but even so must adjut and shouldng give me a code.Distinguished road makes you jewel in roughComment
From 5000 series service manual revision 12
INIT-C C toner dens signal initial VL reading
Lv.2 Details [Not used] To read the initial value of C toner density value (SGNL-C,
REF-C).
After feeding over 100 sheets using a new Toner Container, this
mode can reset this Toner Container as a new one.
Use case When a new Toner Container which 100 or more sheets are fed for
image failure test, etc. is used as a new one again
Adj/set/operate method Select the item, and then press OK key.
Display/adj/set range During operation: ACTIVE, When operation finished normally: OK!
Related service mode COPIER> ADJUST> DENS> SGNL-C, REF-C
From 5200 series service manual
INIT-Y [Not used]
INIT-M [Not used]
INIT-C [Not used]
INIT-K [Not used]
