C3080 E202-0001
  • repeatcopiers
    • Sep 2008
    • 591
    C3080 E202-0001
    The scanner on this copier hits the rail as it moves back towards the home position sensor. Normal operation would have the scanner lower a bit to go under the metal bracket but this one is not lowering, it makes a really loud vibrating sound then throws the error E202-0001.
  • teckat
    • 16083
    Re: C3080 E202-0001
    CIS unit HP detection error
    The HP sensor fails to be ON after the CIS unit moves backward for a specific distance or more.
    :-D --
    Disconnect and then connect the connector, Replace the scanner HP sensor__then check
    Replace the scanner motor__then check
    Replace the reader controller PCB___last resort.
