IR-ADV6065 image got line
  • freedomseahorse
    • Mar 2012
    • 37
    Hello, i have a machine IR-ADV6065 image print got line and i already change the cleaning blade .do you all get this kind of problem?and how to solve this cast?
  • lilleputte
    • Jan 2013
    • 153
    Re: IR-ADV6065 image got line
    attach a printout !
    • browny
      • 81
      replace 1st corona assembly : PN : FM3-7288-000 .
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5011
        Line
        Vertical or horizontal?
        Did you inspect developer,drum,fixing?
        Force stop?
        Print and copy?
        Sample?
        • Canuck
          Tech Specialist
          • 1713
          This machine writes white. Fluff in the path of laser beam will cause a black line...pull out drum unit, clean light path(blow it out}. Canon also has a modified cleaner blade holder for lines
          • lilleputte
            • Jan 2013
            • 153
            Did you fix it?
            /lilleputte
