Problem with Canon IR 2525 i print without error and no printing shows up
  • Simba
    • Aug 2025
    [Jamming] Problem with Canon IR 2525 i print without error and no printing shows up
    Hello ,,
    i have a problem with Canon Ir 2525 printer
    1 user printing fine but the others not printing
    the print job sent to the printer and i can see it in the logs but nothing happend and the printer bibs but the print didn't exit from the printer
    i installed the drivers right from canon
    windows firewall is off
    print spooler is running
    there is no problem when i troubleshoot the printer found
    the printer is active and one user printing correctly
  • Canuck
    Tech Specialist
    • 1713
    Re: Problem with Canon IR 2525 i print without error and no printing shows up
    UFRII driver? Sounds like wrong driver. If it prints from one workstation obviously there is nothing wrong with the printer. IDs,limits,or something. I would make sure its the correct updated driver then create a new port and re-map the port at each workstation. Not a copier issue.
    • SAZ911
      • Mar 2013
      • 193
      Hi,
      I agree with Canuck, it sound like a driver issue in that is picks up the print job but cant process it, then dumps the job and sounds the beep as if it has printed but nothing prints, I had the same issue last Friday where the client was trying to print to a Canon IR 2525i using Canon IR 2020 drivers and did exactly what you described.
      I installed the latest UFRII driver and all was well.....
      Good luck....
      SAZ911..........
