Black Strikes on prints Canon IRADV C5051i
  • niyaskarimba
    • Sep 2014
    • 110
    [Misc] Black Strikes on prints Canon IRADV C5051i
    Dear All,
    Some of our IRADV 5051 series machines is giving black stikes on the print.
    We already replaced black developing unit,ITB Unit and fixing unit and cleaned all the paper path.
    Still the black strikes are comming.
    Please suggest some possible solution for the issue,also attached the test pages.
    Thanks in advance.
    • 16083
    Re: Black Strikes on prints Canon IRADV C5051i
    Did u check drum for arc marks _?
    U said on Prints, is issue on Glass copies_?
    Do the travel on continuous prints, as in various areas_?
    • niyaskarimba
      • Sep 2014
      • 110
      Yes,while copying also same(Glass/feeder).I cannot find any arc marks on drums.Also atried to replace entire process assembly.
      If we print 5 or 6 pages strikes will start appears.And the strikes are not on the same portion of the prints or copyies.
      • JPiek
        • Oct 2014
        • 435
        Looks like some loose toner wandering around in the printer, dropping down on the ITB and then picked-up bij the paper.
        Have you replaced only the ITB, or the cleaning blade too ?
        Edit: what happens if you make 20-30 copy's of a white A4. You get more or less stains/stripes ?
        Johan
        • niyaskarimba
          • Sep 2014
          • 110
          I replaced the whole ITB Assembly.
          When we copy or print more pages,it remains same.Srtikes not increasing or decreasing.
          We have Almost 10 machines having the same issue.
          • JPiek
            • Oct 2014
            • 435
            You have to order the cleaning blade seperatly...
            Oh, i really meant to copy 20-30 blank pages, there is no toner added then...
            Do all 10 have the stripes on the same spot ?
            Johan
            • niyaskarimba
              • Sep 2014
              • 110
              Before i changed the cleaning blade with new one for one of the machines,any ways i will try to change new cleaning blade for this machine too.
              all the 10 machines giving srikes on diffenent,different spots.But the strikes look like same.
              Some pages will come out without strikes,but after some copy it will be back and strikes are not uniform.
                • 16083
                Replace Secondary Transfer Roller
                > then run Copier>Function>Cleaning>TNR-COAT
                secondary transfer roller should be yellow in color.
                Ten printers with the exact problem ?? are they in same building location
                • dan7777
                  • Dec 2012
                  • 680
                  If all ten machines have same problem my bet is on the toner did not come from Canon. I have seen canon toner boxes look like canon except the hologram sticker was not the same. Nothing you can do about that except buy toner from Canon. I have a dozen or so machines and none do this. If the toner came from Canon I have not seen this problem.
                  • niyaskarimba
                    • Sep 2014
                    • 110
                    The toners all are original Canon.We have more than 130 machine,only few machines giving this problem.
                    All the machine are not in the same locations.
                    I thought this will be a common problem for this series.
                    Anyway i will change the trasfer roller and run TNR-COAT
                    Thanks for all your supports.
                    • easymusgrove
                      • May 2017
                      • 9
                      I Would go straight to the Parts room and get the ITB cleaning ASSY ! FM4-7244-020
                        • 16083
                        that was a 2016 post
                        • Rachid.Akli
                          • Oct 2011
                          • 595
                          Try to explore paper quality. Paper dust may pollute the machine. Clean the machine air filter.
                          What is the activity of this customer?
                          Rachid
                          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
                            • 16083
                            Originally posted by Rachid.Akli
                            Rachid
                            That was a 2016 post , Look back😱
                            • rudysemira
                              • Oct 2016
                              • 108
                              Dear All,
                              Thanks in advance.
                              I believe that is fixing unit issue check and inspect the hot roller...good luck
