e00020
  • edpianix
    • 30
    [Misc] e00020
    my canon ir 5000 got this error:
    e00020
    > toner hopper full
    >developer got empty
    > I try to install this hopper and developer to the other machine, function well.
  • JPiek
    • Oct 2014
    • 435
    Re: e00020
    Code: E020-0000
    Code E020-0000
    Description The hopper connector is left disconnected. The hopper motor (M9/M10) is faulty. The toner sensor (TS1/TS2) is faulty. The DC controller PCB is faulty.
    During printing, the toner supply signal is '0' (absence of toner) for 2 mins.
    Maybe your answer can be found in this thread ?
    http://www.copytechnet.com/forums/ca...20-0000-a.html
    Johan
    • dan7777
      • Dec 2012
      • 680
      Re: e00020
      e00020
      > toner hopper full
      >developer got empty
      The code is in the hopper connector and hopper motor (m9/m10). Toner falls around the motors and shorts them which in turn shorts a fuse in the main controller. I also saw where the hopper connector pins are pushed in or burnt. You can replace the fuses on main controller. I don't know which fuse to check on main controller. Maybe the main controller is bad and that is why the hopper worked on another machine. It has been a long time since I worked on those machines but I think you can watch the motors turn. Part check 5 is for M9 hopper stirring motor. Part motor check 6 is for the hopper supply motor. I read where if the developer gets empty the sensors inside or in hopper could throw that e020 code. I hate it when it could be a half a dozen things but that is our job we chose.
      • edpianix
        • 30
        Re: e00020
        it is the dc con where can we locate the fuses on main controller. can you show the images of those fuses.
        Thanks. may God bless
        • dan7777
          • Dec 2012
          • 680
          Re: e00020
          They look like small light brown resistors. You can put a meter on them and ohm them. I don't remember if that board has a lot or not. They are numbered. Maybe something like fu 107.
          • edpianix
            • 30
            Re: e00020
            Thanks for the information. May God bless you always.
            • edpianix
              • 30
              Re: e00020
              hello, Good day,
              i have been searching all parts in the d c controll board of canon IR 5000, I did not found a fuse or symbol FU, or light brown like resistor.
              any idea pls.
              this is the dc controller of IR 5000, i can't see any fuse here13166034_1154866621210563_1004266215649058687_n.jpg13239214_1154866637877228_5396503831694343358_n.jpg
              • dan7777
                • Dec 2012
                • 680
                Re: e00020
                hello, Good day,
                any idea pls.
                this is the dc controller of IR 5000, i can't see any fuse here[ATTACH=CONFIG]32882[/ATTACH][ATTACH=CONFIG]32883[/ATTACH]
                Maybe I was thinking about the 5070 series? Used to get E025 codes where the motor blew the fuse. Those boards have a lot of fuses on them. Sorry. Most of my customers have upgraded to the advanced series.
                • edpianix
                  • 30
                  Re: e00020
                  thanks.
                  as of now the status of the machine are running, but the error comes out when the developer got empty.
                  just hope somebody has an idea.
