canon ir adv 6055 jamming
  • dohha
    • Aug 2013
    • 12
    [Jamming] canon ir adv 6055 jamming
    hi, I have canon IR Adv 6055 machine ,if the right deck FULL of paper(about 1000 sheet or more ) it would jam at pick up roller every ~ 20 copy
    jam code indicate delay jam at pick up roller ,l have replaced all rollers ,and pick up assembly with no vial
    please help
    thanks in advance
  • onlyinnewfoundland
    • Apr 2013
    • 235
    Re: canon ir adv 6055 jamming
    please help
    thanks in advance
    Hi
    Can you possibly get the jam code?
    I have had this on a C7065 series machine which has the same pickup system in the main engine basically. I had a jamming problem like this where I replaced the pickup unit and everything but it would still jam, it ended up being the motor in the back of the machine. It's not terribly difficult to take out, but the service manual that I had for the machine did not include the steps - how convenient!
    • dohha
      • Aug 2013
      • 12
      the jam code is 0101 delay jam at PS19, which Motor did you replaced?
      thanks a lot
      • MunsterTech
        • Sep 2014
        • 381
        hi,
        not sure about the jam code now as it was some time ago, i had a issue with jamming in the right deck, intermittently at first then got worse, replaced all the rollers and it would work, then come back in the next day for jamming, replaced pick up assy, no help still jamming, checked the actual deck itself, made sure the lifting plate was level when coming up to the rollers, what it turned out to be was on the deck at the back is the little white plate that locks...that had loosened and moved ever slightly over to the left, causing intermittent jamming...hope it helps
