Canon ImagePress C6000VP Error Code
  • Laka
    • Nov 2015
    • 36
    [Error Code] Canon ImagePress C6000VP Error Code
    Anyone know what the error code,E00000-0202-05 is. The machine starts, the message will appear and the machine then turns off after 30 seconds.!
  • Setright
    FSS / SPM
    • Nov 2008
    • 247
    Re: Canon ImagePress C6000VP Error Code
    Assuming the coding is the same for a 6010, I found this in the TSM:
    0x02 Fault: fixing heater, fixing heater
    driver PCB
    At warm-up rotation, the fixing
    roller main thermistor detecting
    temperature fails to increase by 10
    deg C within 100 sec.
    X=2 indicates Fixer two.
    • Laka
      • Nov 2015
      • 36
