Print quality issue in ir-a-c5240 i
  • gksapple
    • Apr 2014
    • 116
    [Misc] Print quality issue in ir-a-c5240 i
    having a print quality issue while printing jpeg.file converted as pdf file
    *while printing jpeg file quality is good
    *same file converted as pdf then quality differs
    ps enabled
    ps driver used
    but still quality issue is there
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Print quality issue in ir-a-c5240 i
    Did you compare file sizes? Converted pdf file is probably much smaller.
    • gksapple
      • Apr 2014
      • 116
      both files are same in size
      • charm5496
        • 2387
        what are you using to convert the file to a PDF?
        The quality should be set to high for the conversion process
