Anyone know the 4 pin configuration of this pinset? I'm thinking 1 & 3 are for enable/disable, 2 & 4 are for count/ground. Just need some verification on this. Thanks, L.
Canon iR5055 J1060 Connector
Loren
not sure at the moment, but the one with the jumpers is enable. look at the general diagram to get the signal lines. you can verify the enable jumper wire first so you have a reference which pin is which. from there you could see the other signal lines.You could also use an analog meter to see the needle jump when the count is sent. or use a pulse stretcher circuit with an led to see it count. Of course once you find the jumper that only leaves two wires, just need to know which one is the pulse
