IR 5000
  • ernesto
    • Oct 2011
    • 430
    IR 5000
    Hi,
    Duplex mode is twisting the paper and for these reason the image.
    It seems everthing is right, I cannot see anything broken. Does anyone know the problem?
    A4R it is working right.
    I hope to hear from you
    All the best
  • kuby
    • Oct 2007
    • 1405
    Re: IR 5000
    You might want o make sure the Arm, Flapper(FB5-3394-000) is not cracked. If it cracks it does put enough pressure and the paper shifts when going into the duplexer. Look on Figure #351, item #8.
    • MIKON
      • Jul 2015
      • 187
      Re: IR 5000
      Check the steel roller that is on top of the foam roller on the duplexer where it exits the duplexer.
      The ends of the roller get worn and pop out of postion
      • charm5496
        • 2387
        Re: IR 5000
        B/W IR-5000 from 16+ years ago?
        Just about every roller and guide in that duplex unit could be a suspect for skewing the paper at this point. Have you pulled it apart and inspected everything?
