imagepress 7010 anti-fraud?
  • butitsmyfirstday
    • Feb 2011
    • 60
    Good afternoon everybody, I have what looks to me like a fraud protection issue. When ever I copy anything in color the entire page prints with dashed blue lines. When I copy the same images but set the copier to b/w the image copies fine. I have had Canon at my shop 4 times but they have been unable to fix the issue. I've attached an example, any help would be really appreciated. Thanks.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: imagepress 7010 anti-fraud?
    It's look like protection but this is pwb issue.Don't know which one. Main controller maybe?
    Any errors in the past?
    • butitsmyfirstday
      • Feb 2011
      • 60
      Hi Zoraldinho thanks for responding. We just purchased the machine from a broker so we don't really know if this is a new problem, everything else seems to be working without any issues. Thanks again.
      • teckat
        • 16083
        Is issue off glass color copies and network prints.
        Or just on Glass copies_?
        • butitsmyfirstday
          • Feb 2011
          • 60
          So far we've only been able to test off the glass and test prints from service mode. The A2200 server had it's hard drive removed so as soon as the system disks arrive we will test that...
          • teckat
            • 16083
            Internal test prints have this issue_?
            • butitsmyfirstday
              • Feb 2011
              • 60
              No sir, just off the glass...
              • teckat
                • 16083
                Try and run a Full Auto Gradation , see if CCD throws an error code or message concerning gradation print on Glass.
                • butitsmyfirstday
                  • Feb 2011
                  • 60
                  Ok, I'll give it a try as soon as I get back to my shop. Thank you for taking the time to help me out...
                  • butitsmyfirstday
                    • Feb 2011
                    • 60
                    Ran the full adjust and it completed with no errors.
                    • teckat
                      • 16083
                      Ok,
                      Now take one of those gradation prints, place on Glass and make a copy of it.
                      See if those digital tracks appeare_?
                      • butitsmyfirstday
                        • Feb 2011
                        • 60
                        Ok, I tried that and the tracks still appear...
                        • teckat
                          • 16083
                          Print out P PRINT settings
                          Clear RCON, power of _on
                          Re-Input the RCON Settings
                          Test again
                          • butitsmyfirstday
                            • Feb 2011
                            • 60
                            Ok, I'll try that in the morning and let you know how it goes. Thanks again and have a great night...
                            • teckat
                              • 16083
                              Ok
                              Also try to remove the S-B Sub PCB board on Main controller & reseat it.
                              It should be the third board down.
