Canon IR1600
  • Ibrahimba
    • Jun 2016
    • 10
    [Error Code] Canon IR1600
    IR1600 - error E100. I replaced DRUM UNIT or error remained. How to solve this problem?
  • laitang
    • Nov 2012
    • 627
    Re: Canon IR1600
    1) Drum unit:
    Is the drum unit installed in host machine?
    NO : Install the drum unit.
    2) Connection:
    Is the connection of the connector (J908) on the BD detection PCB, connector (J907) of the laser unit, and connector (J102) on the DC controller PCB normal?
    NO : Correct the connection.
    3) Laser/scanner unit, DC controller PCB:
    Try replacing the laser/scanner unit. Is the fault corrected?
    YES : End.
    NO : Replace the DC controller PCB.
    • techandtrader
      • Jun 2016
      • 335
      Re: Canon IR1600
      Common problem that the tab on the drum breaks off on the back side. Then shutter doesnt open on laser. Then laser error.
      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
