IR3025
  • Ibrahimba
    • Jun 2016
    • 10
    [Jamming] IR3025
    On Canon IR3025, wen i coppy simplex, it has OK, but when coppyed duplex it jamming paper near DRUM Unit! When push back door coppy 10-15 coppyes and jamming again. Whats wrong?
  • sajith9544
    • Sep 2013
    • 5
    Re: IR3025
    it is due to moisture in paper..check your paper output is it rolled..replace with newly fresh paper..if still have problem use a different company paper..
    • kuby
      • Oct 2007
      • 1396
      Re: IR3025
      What have you done to the machine so far. Did you install the door kit, remove the foam cushions for the flapper on the right door, changed feed rollers. Does not sound like a moisture issue to me.
