No power mf216n
  • armin2570
    • Jun 2015
    • 44
    No power mf216n
    HI
    I have a canon mf216n that problem is no power I replace power board no different but replace main board (formatter)power on and work
    Now I need file dump ic flash mf216n for repair main board
    Thank you
  • apoxi
    • Nov 2015
    • 45
    Re: No power mf216n
    Originally posted by armin2570
    HI
    Thank you
    • armin2570
      • Jun 2015
      • 44
      Re: No power mf216n
      Originally posted by apoxi
      ■■After Replacing
      1) After replacing the PCB, enter the serial number in "Location " of System Management
      Settings from remote UI or local UI, and confirm the serial number.
      2) Check that OK is displayed in COPIER > OPTION > SERIAL > SN-MAIN.
      • For the detailed procedure, refer to the chapter on service mode.
      3) COPIER > OPTION > BODY > LOCALE
      To set country group.
      1: Japan
      2: North America
      3: Korea
      4: China
      5: Taiwan
      6: Europe
      7: Asia
      8: Oceania
      Setting range: 1 - 8 (Service part default value: 2)
      4) Execute the following service mode to enable this setting.
      COPIER > FUNCTION > CLEAR > ALL
      5) If the user has printed the user data list and saved the address book before the
      replacement, ask the user to return the settings back to the original values.
      • Ask the user to load the address book from remote UI.
      1. Start remote UI and log in in administrator mode.
      2. [Settings/Registration] > [Import/Export] > [Import]
      3. Select the address book file to be imported, and click [Start Importing].
      4. Click [OK].
      thank you for help amd support me but i need file dump ic flash (Winbond 25Q256) for re program the ic that main board repair
