canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page is ok
  • Santosh_san
    • May 2025
    [Misc] canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page is ok
    I have a Canon iR3035 photocopier Machine it have a problem of CCD laser scanner while i'm trying copy through scanner it prints 1/4 inch down and a black line is prints on the top of the paper but Configuration page and computer print out is perfect.. but from scanner adjustment is needed..
    • 2621
    Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
    service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
    • techandtrader
      • Jun 2016
      • 318
      Can depend. If you are using the feeder. The adjustment in service mode for Y is different than adjustment mode for Y off the Glass.
      Make sure you are using the right one.
      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
      • Santosh_san
        front cover values are not working so i changed the value adj-x-20 to adj-x-1 it cleares but on the top of the paper thin black line comes what can i do?
        • Santosh_san
          No i'm using scanner not feeder every this is ok the scanner is just scanning 1/4 inch higher vertically but configuration page and computer prints comes ok...i setted the adj-x-20 changed to value 1 problem solved but a thin black line is comes on the top edge of the paper
          • songela
            • Mar 2008
            • 216
            You can try applying TOP, T or BOTTOM, B non-image area margins (blank) under
            SERVICE MODE > COPIER > ADJUST > BLANK T/B
