Canon IRA C4025i internal finisher
  • Babelman
    • Dec 2015
    • 30
    Hi I am getting a jam message, indicating in internal finisher but can't see anything, I know very little about these. Before this the copies where coming where coming out crumpled and it has a new fixing unit.Very grateful for any help
    L CODE P
    02 1400 00
    00 0A0A 00
    00 0100 01
  • rayaeek
    • Apr 2015
    • 15
    Re: Canon IRA C4025i internal finisher
    . .. nns
    Sent from my SM-G901F using Tapatalk
    • rayaeek
      • Apr 2015
      • 15
      Ensure the stack tray hasn't gone beyond upper limit. Lower tray down manually and restart.
      • Babelman
        • Dec 2015
        • 30
        Thanks what is the best way to do this, as I am a beginner..
        • charm5496
          • 2387
          there is an opening on the under side of the tray in the rear corner. You can use your finger or a small flatblade to push the gear gently toward the front of the copier to release it and lower it down.
          • Babelman
            • Dec 2015
            • 30
            Great tip thanks,now have E0532-0001 have read what says in service mode, just dont understand the terminology
            • roho
              • Mar 2009
              • 844
              Chances are you need to split the finisher and put everything back to home position. I'd also be upgrading firmware. These finishers can get out of position after a jam. Check to see if the gripper is moving forward enough to allow the stapler to move to home position on boot up. You can remove the inner covers of the finisher and defeat the door switches for observation.
              • charm5496
                • 2387
                yeah, these little finishers can jump track and get out of alignment rather quickly. Like roho said, you are going to have to remove it from the machine and pull the top off of it so you can get the fingers for paper eject, stapler and everything else back into alignment. Take your time though. Its all plastic and can be frustrating as hell when working on it.
