Canon IR7105
  • jimmycabral
    • Jun 2016
    • 35
    Canon IR7105
    I have problem with our machine...IR7105 once i use to copy it work fine the print is clear but when the it print from computer the print went bad look like the the drum worn out. Anyone have idea what i need to do appreciated.
    jc
  • songela
    • Mar 2008
    • 216
    Re: Canon IR7105
    Post the two samples please, for copy and printout, also note that the resolution is higher in print mode than in a copy mode.
    • jimmycabral
      • Jun 2016
      • 35
      Re: Canon IR7105
      Copy.JPG[Copy Sample]Print.JPG[print sample]
      These are the samples from my IR 7105 Canon. You reply will help to decide the part need to be change. It might not show clear but the copy sample is perfect clear and the print has black bands at the non operator side.
      regards
      JC
      • songela
        • Mar 2008
        • 216
        Re: Canon IR7105
        It seems those are shots from a phone camera which can't give enough contrast, yet I can't figure out you printed a 'Blank Document' as nothing appears on the printout.
        You can use the same machine to scan the samples and they will appear far better, use the SEND function:
        SEND > Destination: FILE > SMB > BROWSE, then navigate to a shared PC folder.
        • jimmycabral
          • Jun 2016
          • 35
          Re: Canon IR7105
          These are the samples of the copier print quality.
          thanks for the prompt response.
          JC
          • songela
            • Mar 2008
            • 216
            Re: Canon IR7105
            I would expect you to present samples from a printed text document and a copied text page. Does anything change if the printed page has text or graphic on it?
            to cut the long story short try the folliwing:
            1. Primary Corona Ass'y - Replace or clean the wire, the grid and the interior
            2. Pre-Transfer Corona Ass'y - remove its top cover and empty/clean any accumulation of spilled toner
            3. Pre-conditioning lamps - clean
            4. Blade - replace
            5. OPC Drum - Visual inspection, if worn replace
            • jimmycabral
              • Jun 2016
              • 35
              Re: Canon IR7105
              Thank you for your reply ... your input is very helpful! I will post an update once it done.
              Again appreciated guys....
              JC
              • vigour
                • Aug 2010
                • 1038
                Re: Canon IR7105
                That drum is ASI not OPC
                • songela
                  • Mar 2008
                  • 216
                  Re: Canon IR7105
                  Amorpous Silicone, thank you!
