color adjustment
  • 4raddoo
    • Oct 2011
    • 30
    [Misc] color adjustment
    Please someone help me to adjust my color setting well? I tried to do full adjustment but when the first printout came out and am trying to do the second test page the machine will only indicated that i should place the paper correctly and i tried this several times but is not working. any help. the name is canon IR C4080.
    please find attached problem.
  • sharptech1
    • Oct 2011
    • 163
    Re: color adjustment
    if door specs are correct, cam home the lasers
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 4961
      Did you try to clear registration? Are you a tech or user?
      Practice makes perfect
      If you want something done right, you have to do it yourself
      • dan7777
        • Dec 2012
        • 680
        Black at back side. Sometimes you need to turn paper around on glass. There are some sensors that look at the ITB belt and may be dirty.
