Canon MF729cdw quality issues out of box
  • wragsdale
    • Jul 2014
    • 188
    You'll have to excuse me because I have never serviced a Canon. One of our customers had one from their main office shipped to them and had image quality issues out of the box. The machine currently has around 130 on the total counter. The customer had already replaced the toner cartridges only to observe the same image problems. I've attached some samples.
    SKMBT_C45216063008030_0001.jpgSKMBT_C45216063008030_0002.jpgSKMBT_C45216063008030_0003.jpgSKMBT_C45216063008030_0004.jpg
    The first image shows my very first print which seems to be a loss of transfer. Immediately after printing that, I tried again and had no loss.
    The second image was from a 7 page report that printed perfectly except for the last page which has the horizontal black bar. If you look close enough you can see a residual "Envelope Cling Prevention" which indicates a repeating pattern with a distance of 75-76mm. I'm guessing this is the drum.
    The fourth image (I'm skipping here, sorry) was my first image gradation adjustment, which again shows that loss of transfer. BUT, you can also see what I'm assuming is bias leaking from each color developer.
    The third image is the same gradation adjustment chart after having performed some of the cleaning adjustments and the image gradation quick adjustment.
    I'm not sure where to go from here. I was going to pull the transfer belt, but couldn't figure out how to remove the toner cartridge assembly nor do I have access to a service manual. I appreciate any and all help!
  • wragsdale
    • Jul 2014
    • 188
    Re: Canon MF729cdw quality issues out of box
    Bump. Anybody?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Hi
      I also think it is itb.
      I don't have manual for this model but hp cp model have a similar engine.You have nothing to lose.
        • 16083
        Originally posted by wragsdale
        Bump. Anybody?
        Do not disassemble or repair the machine yourself
        If you disassemble or repair the machine yourself, it may not be covered by warranty.
