2 side copy problem- IR 7105
  • jimmycabral
    • Jun 2016
    • 35
    Hello, I need help from you guys: I have canon machine have problem with 2 side printing, it print offset at the trailing side around 11 mm in second side. I tried to adjust from the service mode but it don't work.
    Here is the service mode i used: copier > adjust then feed-adj then i used to change the value of regis and adj-refe but it don't work. I appreciate your advice.
    It was printed from service mode ...copier > test> PG 31 the 2-side (1)
    Cheers
    JC
  • mramlawi
    • Jul 2011
    • 838
    Re: 2 side copy problem- IR 7105
    looks like also u have the problem on the 1st side try another drawer some times drawers make problems , try to use the bypass 2 sided and tell me what the result.
    Distinguished road makes you jewel in rough
    • jimmycabral
      • Jun 2016
      • 35
      Here is the result from the bypass. The right part of the image is the leading edge and it is offset around 11mm i do some adjustment but it don't work:
      result from : copier > test >PG
      type: 31
      pg-pick: 6
      2-side: 1
      thanks for any input.
      JC
      • songela
        • Mar 2008
        • 216
        I suppose the leading edge should be on the left side of the image for a Canon copier because the scanning lamp is o the left of the platen glass and cans from LEFT to RIGHT. Vice versa could be true for Xerox, may be.
        • jimmycabral
          • Jun 2016
          • 35
          This offset image happen only in 2 side copy or print. In one side copy/print the position of image no problem. Anyone can help me on how to set the image position in duplex printing?
          thanks
          JC
