Canon IRAdv 8105i Send option is missing after Replacing HDD
  • niyaskarimba
    • Sep 2014
    • 110
    [Misc] Canon IRAdv 8105i Send option is missing after Replacing HDD
    One of our IR8105i machine's send option is missing when we replace the HDD and reloaded the system software through SST.
    But after that the send option is missing.I already checked UI send on service mode it is 1 and also checked ST-Send on License trasfer,the license is also no trasfered.
    I tried to initilize all data setting,still it is same.
    Any body please advice me any other posibilities for missing the send option from the main screen.
    Please go through the attached for you reference.
    Thanks in advance
  • teckat
    • 16083
    Re: Canon IRAdv 8105i Send option is missing after Replacing HDD
    Thanks in advance
    Make sure u registered SEND (check mark) in SST Firmware before loading.
    open SST check the Registered Firmware Menu / open 8105i string / mack sure SEND is registered
    Reload Firmware (
    choosing Overwrite All) or select under SINGLE
    • niyaskarimba
      • Sep 2014
      • 110
      Reload Firmware (
      [ATTACH=CONFIG]33423[/ATTACH]
      I will check and update you the status.
      Thank you so much for your support
      • niyaskarimba
        • Sep 2014
        • 110
        We reloaded the software & selected the send as you adviced.Now the send option returns.
        Thanks for your support
        • teckat
          • 16083
          HatTip_2.jpgwelcome
