advanced 6255 scan/copy
  • roho
    • Mar 2009
    • 844
    [Misc] advanced 6255 scan/copy
    I have a advanced 6255 when scanning two sided copies from the df have a bad bleed through on the second side. It doesn't do that off the glass, nor when simplex copies from a duplexed original. I've checked the ccd and white plate settings, and performed a rcon clear. I manually inputted the door lable values. Wondering if anyone has had this issue before, right now I'm leaning towards the controller(reader).
    Thanks in advance!
  • teckat
    • 16083
    Re: advanced 6255 scan/copy
    Thanks in advance!
    Did u use printers "Controller System Error Diagnosis Tool"_?
    • roho
      • Mar 2009
      • 844
      No, I hadn't. Is this also valid for the reader, I thought it was just the main unit.
      • hidius
        • Jun 2015
        • 128
        You can erase the background color of the original and prevent the original image on the reverse side of thin originals from appearing on the copies by using[Background Density].
        Setting procedure:
        1. Press [Copy] -> [Options] -> [Density].
        2. Press [Background Density] -> [Auto]or [Adjust].
        โ€ข If [Auto] is pressed, the exposure of the original image on the reverse side is automatically adjusted.
        โ€ข If [Adjust] is pressed, the exposure of the original image on the reverse side can be manually adjusted.
        Try manually adjusting by lowering the bar and see if it makes a difference. I've had this problem on an Advanced 8205, so i assume it'll be the same for the 6255 as well.
        • roho
          • Mar 2009
          • 844
          That's a good suggestion. The customer has said that this has been a recent development, so I immediately thought of the issues I've had with the reader pcbs in the past. I will check that out as weel, at least to see if it does affect anything. Thanks!
          • roho
            • Mar 2009
            • 844
            Back there today. The device is using uniflo, was able to have a customer sign in long enough to fully test today as well. Density settings did change the output, but not enough, replaced the reader pcb, input specs, works great now.
            • teckat
              • 16083
              good find/
              but bet u had a connection issue on that Reader Pcb. / seen many flaky connectors on Reader Boards
