Re: IRA8105 smear or dropping toner.
There is one Thing you must know about the adv 6xxx and the 8xxx series... They are "White Writer" , means a soiled Laser mirror or Polygon means not faded but soiled prints. Maybe you shound give it a try. Regarding the Jam, there a multiple issues on this Box because of the using of bushings instead of ball bearings. Inspect the delivery assy carefully for seized shafts, also you should look at the assy that drives the delivery assy, there exists a modificated one with ball bearings, while the original one with bushings tends also to stuck.
Reagarding the 108 Jam, i found a Bulletin for you:
0108_0215 jam_en_01.0.pdf
and the printer pulls out weird 11x17 light yellow paper that had shadow like front to back
