E732 AdvC5045
  • repeatcopiers
    • Sep 2008
    • 591
    E732 AdvC5045
    Customer gets E732-0001 every morning upon powering on their AdvC5045. Once they power off and back on it works fine, but the next morning it happens again. The service mode says to check connector, got that.....but the 2nd remedy says Check the power of the Scanner ->whether to performinitialization at start-up? I'm not familiar with this, could someone enlighten me?
  • charm5496
    • 2387
    Re: E732 AdvC5045
    I would pull both main controllers out and reseat the RAM on them, clean the connectors and then make sure there are no bent pins going into the riser PCB. You might have to replace MN-CON2
    • Burdy500
      • May 2016
      • 44
      Re: E732 AdvC5045
      first you should try to turn of deep sleep in service mode, maybe you got luck..
      • repeatcopiers
        • Sep 2008
        • 591
        Re: E732 AdvC5045
        [QUOTE=charm5496;524934]I would pull both main controllers out and reseat the RAM on them, clean the connectors and then make sure there are no bent pins going into the riser PCB. You might have to replace MN-CON2[/QUOTE
        Does it make sense that when they wake it up during the day it wakes up just fine but when they wake it up in the morning it gives the error? Im recalling something years ago on the ir3300 copiers that would throw an error and the fix was changing the sleep to low power mode or high power mode......something like that.
        • repeatcopiers
          • Sep 2008
          • 591
          Re: E732 AdvC5045
          Are you talking about turning off auto sleep in service mode or is there something else I'm not seeing.....will it ever go to sleep if this is turned off?
          • Burdy500
            • May 2016
            • 44
            Re: E732 AdvC5045
            I mean in servicemode. not in usermode Copier/function/user/sleep 1 》0
            • Burdy500
              • May 2016
              • 44
              Re: E732 AdvC5045
              it will never go to sleep then. I use it sometimes when mfp's won't get awake after 1st print in the morning. good luck!
              • Burdy500
                • May 2016
                • 44
                Re: E732 AdvC5045
                and install latest firmware for this bugfix ☺
                • repeatcopiers
                  • Sep 2008
                  • 591
                  Re: E732 AdvC5045
                  Reseated Main Controllers 1 and 2, problem fixed. Thanks!
                  • Helpdeskforum
                    • 28
                    Re: E732 AdvC5045
                    👍tnx for your update
                    • charm5496
                      • 2387
                      Re: E732 AdvC5045
                      awesome man, sometimes they just get loose and the connections are not any good then
