canon ir 2525 firmware
  • pramod
    • Jul 2010
    • 21
    [Electrical] canon ir 2525 firmware
    Hello Friends,
    I have some machines 2525 -110volt and i upgraded firmware ,after upgrading first tray is not working , actually firmware is different in 220 volt machines and what i had done is uploaded that one in 110 volt machine . Please share if any one have 110 volt machine firmware.
    In 110volt machine 1st tray is 500 sheet(which is having lifting mechanism) and in 220 volt 250 sheets(which is having spring lifting tray) .
    Thank You in advance.
  • teckat
    • 16083
    Re: canon ir 2525 firmware
    Originally posted by pramod
    Hello Friends,
    Neve seen firmware directed for different voltage machines.
    • pramod
      • Jul 2010
      • 21
      Good evening Sir,
      After loading dc-con software lifting of first tray failed and my observation is that lifting machnism is different in machine sold here in India is different than what I got from outside . If possible please share firmware.
      • teckat
        • 16083
        Good evening Sir,
        There is only one ver of models firmware.
        There is no choice between AC Voltages.
          Hi according to the service manual there are three types of DC controller firmware.
          You need you need the right firmware for 250 model which has different firmware to the 500 sheet casette model. I have had a look at the firmware but it doesnt run on windows 10
          Good Luck
          • teckat
            • 16083
            Good Luck
            Only one of DCON each for _iR2530 / 25_DCON_v1703, & iR2545 / 35_DCON_v1703
            for the three different controllers.
            no choice for 110v 0r 220v
              yeah my mistake but it seems there's two versions 15 and 17, version 15 for the 2520 version
              • teckat
                • 16083
                17 is for all vera.
                don't see a separate for 2520:-|
                iR2520 model is EURO\ASIA _ not available in US
                • hemansheth
                  Hi there,
                  from where can I download the firmware for Canon iR 2525 machine. I have two machines one is configured to work comfortably with Windows Server 2012 R2 server while the other seems to throw error of Check the server while performing SMB scanning.
                  I also need latest firmware for Canon iR 33220i and iR3300
                  • Nitin
                    • Jan 2024
                    • 1
                    hi guys first time posting here. where can i download latest firmware for Canon IR2525 220V? I actually need to use scan to mail feature and the current firmware doesn't have that. Thanks.
                    • ADV COPIER
                      Pemain
                      • Nov 2022
                      • 257
                      PM send
                      Let's Drink our Coffee
                      WhatsApp +62895325228383
