canon c2030 bad copy quality
  • kei9tha
    • Feb 2014
    • 88
    Re: canon c2030 bad copy quality
    Originally posted by teckat
    how are glass copies ??
    internal color > on PG10 is ok / a little over saturated , black poor,
    a little offset in main scan (front to rear )
    Perform a REG-CLR in Service Mode, and then running a Auto Correct Color Mismatch & Full Auto Gradation > in that posted order
    lean to laser-----------------------------
    run diagnostics
    glass copies with my color chart are not that bad but not perfect.
    • 20 year tech
      • May 2014
      • 577
      sounds like you checked all the usual suspects, Is there OEM toner installed ?
      • onlyinnewfoundland
        • Apr 2013
        • 235
        That PG10 is interesting. At the top of the sheet you can see the registration is a little odd, also not sure if it's just my monitor here but it looks like the black has a small overlap onto the magenta.
        I have a C2230 doing something similar that just underwent a total PM. All of a sudden the registration on all 4 colours is totally out of whack. In our case I think we replaced most of the common parts including laser and the board that drives the laser with no change.
        Does the machine work okay black and white only?
        • JPiek
          • Oct 2014
          • 435
          #19
          ...if it fails or just seems to get worse: don't forget to clean the patch sensors...
          Johan
          • Portabubblejoan
            • Feb 2016
            • 14
            #20
            Try doing a pg6 and see if colours are lining up correctly.
            If not, do an auto correct colour mismatch from the adjustment and maintenance settings. I take it you have preformed am auto gradation on the device?
            • Herrmann
              • Jan 2006
              • 792
              #21
              The colours are completly misaligned in main scan direction, also faded. Regarding the faded print, i think you sorted something like moist paper out, am i right? Do you have a second Machine in reach? If so, I would interchange the Laser and the HVT Unit, just to be sure, while my 2 cents go in direction of the Laser Unit or its control.
              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
