IR5055 DADF S1 roller turned to gummy bear
  • ReproKev
    • 273
    Customer has an IR5055 with ADF S1 jams on the left side. The rollers weren't turning and the green knob was very difficult to turn manually. I found that a registration type roller (connected via belts to the rollers on the left) deep inside has all of the rubber on it turning to a gooey mush .... same as the old delivery rollers on the IRC3200's use to do.
    It looks like the part # of the roller is FC5-3010. Can anyone verify this number or know of an updated #?
    Pics:
  • charm5496
    • 2387
    Re: IR5055 DADF S1 roller turned to gummy bear
    there are 3 rollers to replace on this DADF that all turn "gummy" and the replacement process takes around 2 to 3 hours when you first start doing this. Canon had a replacement program for the entire DADF at one point as well. The old numbers were discontinued.
    TP11 078a.pdf
    • ReproKev
      • 273
      Thanks for posting that tech pub. That's exactly the problem the machine has. I'm not looking forward to spending that much time replacing the rollers but I may as well do all three while I'm at it.
      • charm5496
        • 2387
        if you are going in there kev, get all 3 rollers. Otherwise you are just going to have to go back in at a later date. I was the one who got stuck doing the majority of these in the shop and in the field, so I got pretty good at it, but you have to explode the back side drive and really tear this thing apart.
        • vigour
          • Aug 2010
          • 1038
          I saw a tech pub on here long ago, where Canon would provide a new exchange feeder
          • charm5496
            • 2387
            they canceled that program years ago vigour. That was a really easy deal for a field tech though.
