Is there a way to delete the rx/tx/print log info on these short of pulling the hdd, before it heads to the wholesale truck
thanks
scott
Initialize All Data/Settings if available in model.
Run it a few times.
The 'Initialize All Data/Settings' feature will erase the following data that is stored in the machine:
- Data stored in inboxes
- Address Book data
- Scan settings registered for the Sending function
- Mode Memory settings registered for the Copy or Mail Box function
- MEAP applications and Licenses
- Data saved from MEAP applications
- The password for MEAP SMS login services reverts back to the default
- Registered SDL (Simple Device Login) user authentication information
- User authentication information registered in the local device authentication system of SSO (Single Sign-on)
- Unsent documents (Reserved documents and documents set with the Delayed Send Mode)
- Job History
- Additional Function settings
- Image forms registered for the Form Composition mode
- Registered forwarding settings
- Key pair and server Certificate settings registered in Certificate Settings in TCP/IP Settings
It is not normally necessary to use this feature, but it is useful for erasing personal or confidential information when returning or disposing of the machine.
To use this feature:
1. Press Additional Functions.
2. Choose System Settings.
3. Scroll down and look for 'Initialize All Data/Settings'.
4. Press Yes.
Note: Main Firmware for copier will remain intact.
=-O
You can erase any received document stored in the Memory RX Inbox or the Confidential Fax Inboxes when memory is full.
1) Press [Mail Box].
2) Select [Memory RX Inbox] or [Conf. Fax Inbox].
Note: [Memory RX Inbox]: To select a received document that has been stored in the Memory RX Inbox.
[Conf. Fax Inbox]: To select a received document that has been forwarded to the Confidential Fax Inbox.
3) Select the documents that you want to erase.
4) Press [Erase].
5) Press [Yes].
6) Press [Done].
Run it a few times.
- Address Book data
- Job History
4. Press Yes.
=-O
