Canon ipf6100 prograff
  • Hydrodip
    Hi all. Wondering if someone can help. I purchased a ipf6100 with the close upper door fault with I bypassed to see if the printer was working, since then I have a multi sensor fault power off then restart on normal power up. In service mode I have maintenance cartridge seems to be not detecting as there is one fitted. Can anyone help. Thanks
    • 16083
    Re: Canon ipf6100 prograff
    codes/
    messages
    This document provides troubleshooting information for Canon printers. It includes indexes of error codes and symptoms to help locate issues. The bulk of the document contains a database of specific printer problems organized by component or function. It also details some sophisticated fault isolation techniques involving issues like paper feeding errors, cutter problems, and imaging failures. Tools are included to help diagnose encoder and nozzle check print faults. The document aims to help technicians resolve printer issues by pointing them to the relevant troubleshooting information for a given error or symptom.
    • Hydrodip
      No error codes. On normal start up on the screen it says upper cover open when it is closed. I bypassed this to try and get printer to work. After I bypassed the switch and turned back on it comes up on the screen multi sensor error turn off wait a while.
      In service mode it comes up as the maintenance cartridge is not installed but that is fitted, tried removing and fitting that doesn't work. Managed to get the printer talking to laptop now but still can't figure out why I can't get it working correctly. Thanks.
        • 16083
        did u see link to troubleshooting guide above ????
