Blank Paper With Print and Copy iR2530
  • semsros
    • 12
    Dear all
    My machine Canon ir2530 (220voltage), it is running normally (not jam or Error code) but print and copy all blank paper out put.
    I already changed:
    1. Drum unit
    2. Developing unit
    3. High Voltage Board
    4. Laser Scanner unit
    please helping me to solve this problem...
    thanks you
  • techwurk
    • 127
    Re: Blank Paper With Print and Copy iR2530
    Is the DV unit turning?
    When I started servicing copiers they used toaster ovens for fusers.....I'm old
    • Helpdeskforum
      • 28
      no image at all? Or foggy? (contact to transfer roller)
      • semsros
        • 12
        Yes, Developer is running normally
        • semsros
          • 12
          Is blank, it is looking like Developing don't provide the toner...
          • roho
            • Mar 2009
            • 844
            Take a look at the hopper assembly, the one piece with a coupling gear can become deformed and disengaged, I've had one issue like that, I believe it was blank prints as well, no error codes from what I can remember.
            • roho
              • Mar 2009
              • 844
              You will have to remove the finisher, if there is one, a host of panels, dev, drum and laser to get to the hopper. The one piece that fits in the back recess has a piece with gears, tends to get bent away and not drive. In my case I had two machines to compare, found the dev level practically empty on the one in question.
