Ink Absorber Near full canon JX510p
  • tibbs
    • Aug 2008
    • 223
    Hello friends, I have a Canon fax JX510p that's showing ink absorber near full. Can anyone say how I must go about clearing this message.
    I have done a all clear in service mode but I get the same message. Am not sure if there is another way to clear this message. Also I have changed the ink absorbers.
    Regards
  • Luther
    • May 2006
    • 682
    Re: Ink Absorber Near full canon JX510p
    Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "Ink Absorber Full" error code....you will have to replace them eventually
    • tibbs
      • Aug 2008
      • 223
      Hey Luther, tried this and it did not work out. Any more suggestions ?
      Regards
      • JPiek
        • Oct 2014
        • 435
        For IP90/IP100 it used to be :
        Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
        1. Make sure the printer is turned off.
        2. Press and hold the Resume button (triangle inside a circle).
        3. Whilst it is held down, hold down the Power button. The green led light should come on.
        4. Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again.
        5. Release the Power button.
        6. Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber).
        7. Turn off the printer and then turn it on again
        Johan
        • JPiek
          • Oct 2014
          • 435
          A heap ofoptions, but no JX510 ?
          Johan
