IR-ADV C5240 printing dark on some photographs.
  • wseyller
    • Sep 2012
    • 1129
    This is a real estate company. Mac PS driver used. They take pictures of some houses with some scenary in the mountains. Some are professional photographers and some may not be. I images look good on the monitor, though I know the monitor may not be calibration and the fact of RBG vs CMYK but they look pretty dark and also over saturated.
    I have replaced components and done auto-gradation. I will say that Canon is not my strongest compared to other brands we sell. I mostly do network installs when related to Canon. I am a Konica Minolta guy.
    The paper quality looks pretty good and they showed me a print out of what is possibly the same file that was printed who knows when that looks more like the monitor.
    Any settings on the Mac driver I can try. Customer uses Adobe Indesign and there isn't much different between that or when printing it from PDF. I have tried Print as image which lightened it up but it look like crap. I changed to let printer determine colors versus Indesign which may have help just slightly but not much.
    No fiery involved.
  • JPiek
    • Oct 2014
    • 435
    Re: IR-ADV C5240 printing dark on some photographs.
    First things first, it;s NOT a photoprinter, alltough the 52xx does a better job than iE a 20xx or 22xx...
    Is it just with printing these photo's ? Do other photo's look good when printed ?
    How do the photo's printed on other printers look, if you compare ?
    can you try a print the photo's via a Windows PC/Driver or via the Printers Webinterface to eliminate the Mac driver ?
    etc. you'll have to play the elimination game to find the answer.
    Johan
    • acfife
      • May 2012
      • 63
      Worth trying the UFR driver as you may get better results.
      imageRUNNER ADVANCE C5240i - Canon Europe X 10.11 (El Capitan)&language=EN
      • wseyller
        • Sep 2012
        • 1129
        Lucky for me that actually worked out well using the UFR-II. Thanks
        Sent from my Nexus 6P using Tapatalk
        • acfife
          • May 2012
          • 63
          Good result
          • madas
            • Aug 2008
            • 313
            Had similar in schools and real estate agents, most photos were fine just the odd couple darker.
            solution adjust the image not the machine.
            Madas
