how to replace and config in service mode for ir3300 heating element ? thanks.
  • lithium898
    • Feb 2016
    • 46
    [Electrical] how to replace and config in service mode for ir3300 heating element ? thanks.
    code = e001-002
    First i try to err clearing in service mode but still showing
    electric wire = OK
    fuser film = OK
    Thermal fuse = maybe OK..
    heating element = broke
    *28*
    analog = temp 31 / HUM 69 / ABS HUM 1963 / DR TEMP 29 / FIX C 38 / FIX E 310
    now.. I replaced the heating element already but err code still showing
    thanks all friend...best regards
  • kuby
    • Oct 2007
    • 1400
    Re: how to replace and config in service mode for ir3300 heating element ? thanks.
    After you replaced the element did you clear in service mode
    • lithium898
      • Feb 2016
      • 46
      yes i did..
      • IndoCE
        • Nov 2014
        • 14
        Originally posted by lithium898
        code = e001-002
        electric wire = OK
        fuser film = OK
        *28*
        Fix e 310 !!!!
        Replace DC board
        • lithium898
          • Feb 2016
          • 46
          Originally posted by IndoCE
          Fix e 310 !!!!
          Replace DC board
          But.. I changed the working normal heating unit of another one .. it works
          • IndoCE
            • Nov 2014
            • 14
            Err 001 sub 002 about resistance subthermistor ... short or dc board misread the resistance from subthermistor
            • Hopper
              • Jul 2008
              • 173
              yes i did..
              What were the key strokes you used? Did you do ERR clear?
