ira250/350 e009
  • alex@wocltd.com
    • 430
    ira250/350 e009
    anyone got any sure fire fix for the e009? squirting a grain of grease as per ati doesnt work and the effort to fit the revised drive assembly seems a real ball ache......
    anyone???
  • charm5496
    • 2387
    Re: ira250/350 e009
    when does the error show up? That helps determine what method of action you should take to fix the issue
    • apoxi
      • Nov 2015
      • 45
      Re: ira250/350 e009
      anyone???
      Change the fixing drive assembly.
      FM0-0071-000
      Fixing drive assembly
      • madas
        • Aug 2008
        • 313
        Re: ira250/350 e009
        Had an issue last year not sure what the code was but there is a known issue with the fixing drive Assy, I changed it and no more codes.
        Les
        • dan7777
          • Dec 2012
          • 680
          Re: ira250/350 e009
          anyone???
          It is a pain. Have a large table to put all the boards on and take instructions. I had to redo my work as there is a sensor on or near that assembly that pops out. I only have had to replace one and the code never came back with the new assembly. Take help for more eyes if possible.
          • Cocha
            • Jun 2013
            • 5
            Re: ira250/350 e009
            I had this issue last year and had to replace the fixing drive, the fault hasn't returned on that device.
            I now have the same fault on two other devices, one of which I am replacing the drive today.
            however what I have noticed is that all three devices are low usage, and the fault occurs when the device attempts to come out of sleep mode.
            when the device is powered off/on it will continue to work with no error.
            I've been advised by canon today to switch sleep mode to high in settings registration
