ir2520 send from email
  • mramlawi
    • Jul 2011
    • 838
    hello ,
    i have a problem in ir2520i i want to send email from it but it didnt work can anyone give the right setup because i have tried too many times but it didnt work,i also tried the gmail but didnt work can anyone please give me the right steps
    Distinguished road makes you jewel in rough
  • mramlawi
    • Jul 2011
    • 838
    Re: ir2520 send from email
    Any one have any idea
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5005
      Didn't work.Come onnnn.Error code? ########
      Did you set Port to 587?
      SMTP server
      SSL
      PORT465 TLS = 587
      valid e-mail
      Allow less secure devices" enabled in the gmail account..............
      • mramlawi
        • Jul 2011
        • 838
        SMTP server
        SSL
        PORT465 TLS = 587
        valid e-mail
        code ##802
        • JPiek
          • Oct 2014
          • 435
          802 points at SMPT server and/or DNS :
          Canon imageRUNNER ADVANCE C5051/C5045/C5035/C5030 e-Manual - List of Error Codes without Messages
          Cause 1 The name of the SMTP Server in E-Mail/I-Fax Settings in Send in Function Settings (Settings/Registration) is incorrect. The DNS server name in DNS Settings in TCP/IP Settings in Network in Preferences (Settings/Registration) is incorrect. Connection to the DNS server failed.
          Remedy Check the name of the SMTP Server in E-Mail/I-Fax Settings in Send in Function Settings in (Settings/Registration). Check the DNS server name in DNS Settings in TCP/IP Settings in Network in Preferences (Settings/Registration). (See [E-Mail/I-Fax Settings] in "Settings/Registration Table.")
          Check that the DNS server is functioning normally.
          Johan
          • mramlawi
            • Jul 2011
            • 838
            thanks for your reply will try it
