Canon IR2535i Fax
  • blackdog
    • Jun 2012
    • 211
    Canon IR2535i Fax
    Hi, hey I just installed a modem on this IR2535i with no install manuals.
    No dial tone? Is there a dip switch involved or plug & play?
    I do have service manuals.
    Thanks for your help
  • 20 year tech
    • May 2014
    • 577
    Re: Canon IR2535i Fax
    shoul be plug and play, was the fax board new in box or used ? there is another board that mounts to the controller, the fax board as well as a battery and several cables
      • 2621
      I am going by memory as the install instructions are not in service manual revision 9.
      There's a fax box another board that plugs onto the main controller and at least one ribbon cable a multi wire cable and a power red/black type cable these connect between the fax box and the main controller.
      Every i model already comes with the battery so I don't think this is needed.
      • 20 year tech
        • May 2014
        • 577
        found the instructions
        Super G3 Fax Board AG1.pdf
        • blackdog
          • Jun 2012
          • 211
          Thanks to all, found problem, ribbon cable folded at connector causing a short.
          No more Fax option on this machine. Lol
