Image class MF6550. Had left door close issue. Had to remove drum shield.
Contact spring on contact spring unit at top bent. Took apart. Also fuser due
to broken actuator which was replaced. Have removed fuser many times
before so aware of all that needs to be done to properly remove and install.
Had removed contact spring unit by removing dc controller and spring unit
guide. The 2 black gears on front lower left of machine were misplaced and had to
order. Tried to reform upper spring in contact unit as new one ordered but on back order.
Replaced 2 black gears.
Now when machine is turned get alternating display with regular screen, then screen
that says load paper cassette 1, then says output tray full, then days paper jam...open left cover.
When first turn on says initializing and machine diagram shows red lite for paper cassette and red circle.
Any help is appreciated. I kmnow it is something that I did. Frank/ Action Photocopy
