error Code E748-9000
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Here again .....
    Other problem.....
    I have changed a MAIN PCB on iRADVC 6075 pouring small cards from old to new.
    Turning on the machine, it appeared the code and despite the MAIN reset, charging the System HDD, I still have all blocked.
    And in the technical manual just says "System Error".
    What happened ?
    Help me ! ! !
  • spectraindo
    • May 2008
    • 313
    Re: error Code E748-9000
    Hi, your problem is the MAIN PCB is not for the IRA 6075.
    Check the part number, it must be FM4-5302-010.
