C3380 Bypass Problem
+ More Options
Posts
  • The clk man
    • 86
    The bypass on my Canon c3380i will not feed any type of paper thru it, when it did work, you could hear the mechanism, but now it barely make a sound when it tries to feed the sheet. I opened the side and looked and saw a shaft with a rubber belt that looked loose and you could lift the left side of the shaft up about .25 of an inch. any thoughts anyone? thanks Robert.
  • teckat
    • 16083
    Re: C3380 Bypass Problem
    did you remove the unit to inspect ???? are u a tech ????
    The multi-pickup roller starts to rotate when the manual pickup clutch (CL5) goes on to start upper separation to pick up a single sheet of paper. When the leading
    edge of the sheet reaches the pre-registration sensor (PS7) and is moved a specific distance, the manual pickup clutch goes off, causing the sheet to arch in the
    registration roller area.
    When the registration clutch (CL6) goes on, the manual feed pickup clutch (CL5) once again goes on to pick up paper. The manual feed pickup clutch (CL5) goes
    off immediately before the trailing edge of paper moves past the manual feed pickup roller; thereafter, the registration roller serves to pull off the paper.
    • The clk man
      • 86
      I haven't yet but plan to in the am. The bypass will feed if you help the sheet through with your hand, I thought maybe the first feed roller might be wore out, it felt smooth to the touch. I appreciate any thoughts on this matter.
      • MunsterTech
        • Sep 2014
        • 381
        hi,
        get this alot especially on older machines, if you look at the bottom of the door on the inside by the hinge, you will see a self tapper screw, large head on it, they come loose, tighten and it will then tighten the hinge to the door again, always that screw especially if its making a grinding noise, if you cant find it, just tighten any screw you see, you might find the screw will not tighten, i carry plumbing tape to make the screw "fatter". hope it helps, sorry no pics
        • Thomasedison
          Renew it. It is also cheaper . Or look at my profile. Will find detailed instructions there
            If you apply force to the lower right area of the door and it works chances are the screw thread is stripped
            • techandtrader
              • Jun 2016
              • 330
              These solutions might fix it but some doors where defective right out of the box. I know because I got to setup a couple. There is a tech pub or article about needing to replace the whole door due to warpage or manufacture fail. Over the years I have seen many replace hinges and everything only to replace the whole door to finish it.
              I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
              • teckat
                • 16083
                all techs hate that door from the beginning of this series production/
                customers also do damage (slamming closed >>> they pay )
                • The clk man
                  • 86
                  where would I be able to get the whole door reasonably priced if the adjustment stated above doesn't work?
                  • The clk man
                    • 86
                    It almost sounds like you enjoyed typing that.
                    • tech28
                      • Jun 2013
                      • 434
                      ClkMan, I have a couple of doors, complete, let me know.
                      • The clk man
                        • 86
                        I found the screw and it was very loose, I turned the screw in until i felt some resistance and then stopped. The bypass fed fine and the paper drawers ran about 10 sheets then jammed I opened the drawer a the sheet didn't male it out, so I am attributing that to wore out feed tires. Thanks everyone for the help, I'll be back asking for help on how to install the paper drawer feed tires as soon as I get them in.
                        • The clk man
                          • 86
                          Could you send me some pricing in case the fix is only temporary? Thanks Robert.
