ir advanced 5045 locked out
  • pontiac
    • 420
    Copier displays certification [ system administrator] also asks for sys. manager id and password when entering service mode. How do we bypass to reset copier.
  • teckat
    • 16083
    Re: ir advanced 5045 locked out
    Default System Manager ID is 7654321.
    Default System PIN is 7654321.
    To disable the system manager ID, both fields listed under Settings / Registration > Management Settings > User Management for System Manager ID and System PIN should have all '0's entered in them. This will disable the login box under the Settings / Registration screen.
    • pontiac
      • 420
      Thanks teckat. that worked but now it is asking for password. Thanks again
      • teckat
        • 16083
        Use same # for password
        Or try 71617000
        • pontiac
          • 420
          Thanks again teckat. We tried those #'s and also 7 1's none of the numbers worked. Is there any other way of resetting the copier back to factory settings. Thanks
          • teckat
            • 16083
            Service Mode > COPIER > FUNCTION > CLEAR>PWD-CLR
            Clear of system administrator password
            Level.1 Details To clear the password of the system administrator set in the user mode.
            Use case When clearing the password of the system administrator.
            Select the item, and then press OK key.
