Canon IRA C2030 location of boot rom
  • doug
    • Dec 2011
    • 198
    Hi Guys,
    I have a Canon IRA C2030 that says "starting" and then the screen freezes.
    maybe I can reseat the boot rom if I knew where its is on this model?
    Any help would be appreciated and thank thank you all in advance.
    Doug
  • luis1984bol
    • Nov 2011
    • 148
    Re: Canon IRA C2030 location of boot rom
    Originally posted by doug
    Hi Guys,
    Doug
    Did you try upgrating the firmware?
    • guitar9199
      • Sep 2016
      • 1100
      Hold down the Control Panel power switch while turning on the Main Power. This starts the Boot System diagnostics. If you get 5 slow, steady blinks on the main power light, you should be good... if it blinks in a high-speed random pattern, you've got an issue. Re-flash the firmware using SST or the firmware files on a USB stick.
