IR3035 emailing
  • ndpace
    IR3035 emailing
    On my IR3035 I have set up the section with the UI under Additional Functions then custom settings then under network settings (bottom right) E-mail/I-Fax Settings . I set this up the same as my IR3570 which works, but I can not get the 3035 to work. I set up the 3570 along time ago and I was wondering if I am forgetting a step.
    The 3035 sends PDFs tot he server just fine
    Thanks in advance, Jim
  • TA_Tech
    • 76
    You dont give any details of your network, but I've had it before on some networks that if you don't configure the machine with a DNS server IP address and Domain name, they won't e-mail, but this is dependant on your type of network. Its worth a try.
    * > system settings > network settings > TCP IP settings > DNS
