Help with Image Runner ADVANCE 8205 Printing backwards
  • QC91
    • Oct 2016
    • 91
    [Misc] Help with Image Runner ADVANCE 8205 Printing backwards
    Hi, we have Image Runner ADVANCE 8205 and every time we print PDF the pages come out backwards I have looked at PDF setting on PC and they are correct we are using UFR II any help would be appreciated
  • teckat
    • 16083
    Re: Help with Image Runner ADVANCE 8205 Printing backwards
    1. Open the PDF file to be amended
    2. Click on FILE...PRINT..
    3. Check the REVERSE PAGES Box
    4. Select Acrobat Distiller as the Printer
    5. Click OK and save as a new Filename
    6. Open the new file and the page order will have been reversed
    • QC91
      • Oct 2016
      • 91
      we had to set the adobe reader to print backwards and have 8205 facedown on the N1 Tray that seems to work when we print from the PC but when we try print from USB thumb drive it comes out in booklet format on the paper I can't see to find the settings to fix this
      • QC91
        • Oct 2016
        • 91
        Thanks teckat for the help we also have problem printing from USB thumb drive it comes out in booklet format on the paper I can't see to find the settings to fix this
        • teckat
          • 16083
          From the printer properties menu, select Device Settings.
          Select the appropriate Output Options for you printer, and click on Apply and then OK.
          • QC91
            • Oct 2016
            • 91
            Thanks for the help I can't seem to find the setting here are some photos it is shrinking the 4 pages on to 1 everytime we use USB thumb drive
            • QC91
              • Oct 2016
              • 91
              • teckat
                • 16083
                check in the driver being used settings
                why do u have LT R as your paper finishing direction ??
                also u have 2-1 selected ????
                • QC91
                  • Oct 2016
                  • 91
                  Hi, teckat we are printing on 8.5 x11 3 hole punched we can't seem to change the have 2-1 selected I will post some photos
                  • teckat
                    • 16083
                    first change paper to read LTR & not LTR R
                    let's start over----------------
                    explain exactly
                    1-what u are trying to print (single sided, two sided, book mode) ?
                    2- paper size ?
                    3-application being used (Word, Pdf's etc.) ?
                    4- driver type ?
                    5- finishing ( staple ) ?
                    6- are u setting up thru the application ?
                    7- are u doing changes in driver properties ?
                    • QC91
                      • Oct 2016
                      • 91
                      adult image host
                      • QC91
                        • Oct 2016
                        • 91
                        1-what u are trying to print two-sided its manual for 3 ring binder
                        2- paper size ? 8 1/2 x 11
                        USB Thumb Drive with PDF files
                        4- driver type ? UFRII
                        5- finishing ( staple ) ? none
                        6- are u setting up thru the application ? no we are using USB Thumb Drive
                        7- are u doing changes in driver properties ? not sure how to Change it on 8205
                        • QC91
                          • Oct 2016
                          • 91
                          Hi, are some screen shots of the USB drive setting on the 8205
                          • teckat
                            • 16083
                            See link----Printing From a USB Flash Drive on a Canon Printer
                            https://help.evangel.edu/hc/en-us/ar...-Canon-Printer
                            Printing Documents Saved on a USB Flash Drive
                            • QC91
                              • Oct 2016
                              • 91
                              Thanks teckat is this the one https://support.usa.canon.com/kb/index?page=content&id=ART165803&pmv=print&impressi ons=false&viewlocale=en_US
