MF TOOLBOX 4.9.1.1 & Windows 10 (Issues since 29/09 update?)
  • nekowaiidesu
    • Dec 2015
    • 65
    Hi all,
    I have a client who uses an iSensys 8280cdw on network. She's using Windows 10 and has the updates enabled. She was away but one of the other employees said the issue started around a week ago despite them only reporting it today. I found that there was a Windows 10 update on 29 September 2016 and wonder if that has created the issue.
    As is there are problems with Canon IJ ScanGear and MFToolbox on Windows 10, but the scanner worked before some time last week.
    I've been trying to find fixes. There are lots of older posts about incompatibilities, in particular a thread on Canon website with 29 pages of people trying to fix this issue - I've tried most or all of those fixes and none have helped.
    I also noticed this person has reported their scanner does not work since the 29/09 patch.
    []Object moved
    Anyone else experienced this? Any issues since that 29/09 patch, in particular with TWAIN drivers and mftoolbox 4.9.1.1
    • 16083
    Re: MF TOOLBOX 4.9.1.1 & Windows 10 (Issues since 29/09 update?)
    Guess u probably did this below
    Start> in the run box type. Services.msc
    Scroll down to Windows Image Acquisition (WIA)
    Right click, select Properties
    Check that Startup type is set to Automatic
    Click Log On Tab
    Check that Local System account , and Allow service to interact with desktop is checked. Hit apply.
    Click Recovery...Click on window next to First Failure, Scroll to Restart the Service. Hit apply.
    if that don't work
    uninstall Canon Drivers & MF Toolbox- re-boot
    than re-install drivers and Toolbox
    https://www.usa.canon.com/internet/portal/us/home/support/details/printers/color-laser/mf8280cw
    • nekowaiidesu
      • Dec 2015
      • 65
      Aye thank I saw that on the Canon forum. Seems that it worked for a lot of people, but those posts are mostly dated back to 2015. Tried but no cigar. There was another person who suggested adding the TWAIN directory path into the Windows system Environment Viariables, tried this too but no improvements.
      I've checked firewall exceptions, rules, turned off firewall, reinstalled drivers, reboots, etc etc. Haven't yet tried 'clean booting' - Will give this a try, but I am highly skeptical that it is a 3rd party process causing the problem. As far as I know (which may not be too far lol) the client has not installed anything new besides the 29/09 windows 10 update which is why I suspect that patch may be the culprit.
      On Monday I'm going to try get them at least scanning over USB with the WIA driver for the time being. Hoping that I'm not the only one experiencing this and maybe the Canon / Microsoft forums will have a flood of angry users looking for answers in the next few weeks.
      If anyone else has had this problem, especially since 29/09, I'd be interested to know.
      Thanks again
        • 16083
        Thanks again
        uninstall all canon drivers & mf toolbox----reboot
        if you have the original user software MF Toolbox /Drivers CD that came with printer ?? download using that
        if not
        then go to that official Canon link posted and reinstall items needed there.
        MF Driver Installation Guide.pdf
