IR2202n
  • Ibrahimba
    • Jun 2016
    • 10
    [Jamming] IR2202n
    I have ir2202n and when i try to print or copy the device ejects error that is jammed paper. Default tray is Tray 1. When I put paper on rear tray device working normally. Device is new( counter:1100). I chaked tray1, pickup roller and separator page. All is OK. What happaned?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5012
    Re: IR2202n
    Check paper size and paper lift mechanism.Jam code?
    • Ibrahimba
      • Jun 2016
      • 10
      Re: IR2202n
      The device when it involves, normally enters the standby mode. When the task action, to display the message that is jammed paper.No error codes, and the first I checked the size of the paper in the tray. Lifter paper works, too.(The user says that he had a paper jam and to have it removed.I checked that there is no paper debris, but nothing I have not found within the device).
      Thnks for the reply!
      • jimmycabral
        • Jun 2016
        • 35
        Re: IR2202n
        If you can provide us the JAM code we can tell you exactly what sensor concern on that issue. It might be delay or stationary on that area.
